Old 11-18-2014, 05:53 PM   #6923 (permalink)
duncan
Originally Posted by MPaulHolmes View Post
I think I forgot to mention b- on controller goes to b- on battery pack and also to motor-. Did you do that? And then b+ on controller to b+ on battery pack and motor+ on controller (all 3) to motor + on motor.
yes
Three motor +ve to my reversing contactor
Battery minus to the motor and the controller
Battery +ve to the controller
Yes - I was worried that I had done it wrong so I put it back in to check it
just now
The check confirmed the same problem
Can I check the parameters using the serial port??
Or using the PiCkit??
