Old 12-28-2014, 09:03 PM   #1 (permalink)
thewanderer
Civic VX - '92 Honda Civic VX
Civic VX shift indicator light connector / wiring
I've recently switched to a federal ECU in my California model 92 Civic VX. The previous owner replaced the gauge cluster when the original had an issue, and the one in now has a shift indicator light. I took the gauge cluster out to check to see if the bulb was burnt out (it isn't) and noticed the 5 pin connector for the shift light was not plugged in. I also realized there is no connector from the harness to plug into it.
I did notice when I was switching the ECUs that there was a pink/green wire going into the harness at the ECU, but I do not know where it goes. I suppose I can run a wire from the ECU to the gauge cluster. Does any one know if the cruise control connector is the exact same as the shift indicator connector? If so, I can grab one from a civic in a local junkyard.
