I just found the thread too.
If you're set on another round, just cut a softer curve in the ribs, position the stringers so there is a continuous 3 or 4 inch gap, roll a roll of flashing metal, cut lengths and roll them (on a cyclone fence or with a skate board in a gutter), then bend it to fit your already-finished frame and rivet or staple it. Or little screws.
Try pulling the rear side tight first and pull the wrinkles toward the front corner.
Another round or prob just tweak this topper until i have to get another truck. I will be restretching the rubber onto the frame when its warm out, which may be a good time to soften the transition. Really i dont loose any useable space, and it should help the flow along the side which moves onto the back, and crosswind flow. My buddy suggested trying rubber cement to weld the seams. Im down. And i would like to cut the tail corners a bit.
Anyways thanks for the input freebeard. Man i need a shop!
