Those 175/70 tires have a 8.5 mm higher sidewall than the 175/65s.
So they were about 3% bigger than the 65s.
If you did not compensate for their size in the odometer readings, and you seemed to use 2% more fuel on them, in reality they were saving you 1%...
If 175/70 R14s were OK, then get the 165/75 R14; those are just a few mm taller.
