Originally Posted by 320touring
Worryingly, having been out on the bike in the shed this evening (on the resistance stand) i'm now wondering if I could design a stand that provides resistance by charging a battery..
Heh, something else to consider!
K-TOR Pedal Powered Generator
That says it puts out 20 watts, which is really not much.
On the higher handlebars, if you're lucky you could go to the LBS and grab a longer shifter cable and housing. If you're adjusting the derailleur anyway, why not.
