Old 05-19-2015, 09:44 PM   #33 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
update
After 20 or 25 miles of normal operation, the problem returned as I began the return commute. I stopped repeatedly, checking one connection at a time until the problem went away again. It turned out to be the connector into the MAP sensor. Back in March or April, when I repaired the fuel pressure regulator the second time, I relocated my extra brake booster and it seems the vacuum line began to conact and stress the wires into the connector for the MAP. Since it was behind and under the air cleaner box, against the firewall, I did not notice. As soon as I repositioned the vacuum line and reattached the MAP sensor connector, the problem went away.
Perhaps the problem is solved, but only driving will "prove" it.
Thanks!
James
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
pgfpro (05-20-2015), phh (07-30-2015)
