Here is a flir image of my diff after a short little highway trip. The hottest part of the diff cover was 120'F about 5 minutes after I parked it, then in the 3 or 4 minutes it took to find the flir SD card the rear had cooled an additional 6 degrees F.
Looks like all the heat is concentrated around the ring, pinion and diff, you can even see where the level of the fluid is.
In the past the hottest reading I could get with a simple inferred scanner on a diff was about 145'F after I had parked the vehicle.
The nitrogear diff cover was $180 shipped (not installed when this thermography was taken).
