Old 04-02-2016, 06:39 PM   #121 (permalink)
serialk11r
What if its too efficient and vacuums out the cylinder causing more air and fuel to be pulled in?
This would be ideal for an N/A diesel in all conditions, because more air is always better for them.
For a gasoline engine this is only good if you want to burn lots of fuel and go fast.
Adjust the cam timing, problem solved.
The Metro has external EGR so it's not important to tune the overlap for efficiency.
