Old 04-15-2016, 05:13 PM   #14 (permalink)
iwcham1979
The car is in the garage, waiting for the new plates, and then the mechanic... Since i dont drive it, i checked the oil level in the container every morning. That mechanic definitely overfilled it with oil, apparently not knowing what he was doing. The pump has sucked in the oil in the accumulator, and he topped up. When the car is off, the oil level starts to rise, and the oil somehow, whether by design or brute force finds a way to drip out. I have managed to take out about a dl of oil by using suringe. Also, i have just read that the oil needs to be GREEN VW PowerSteering oil, whereas the mechanic poured in some red steering stuff. Is all this overfilling, dripping, and using inappropriate oil likely to cause any damage, where there was no damage in the first place. I should have replaced only the accumulator and leave it at that. Nothing more was required, but now...
Some of the oil i extracted:
[img=http://s30.postimg.org/78799l5gt/IMG_0955.jpg]
The correct stuff:
G004 000 (M2), which is actually the the new G002 000
