Old 07-21-2016, 02:59 PM   #36 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Originally Posted by RustyLugNut View Post
As you pointed out and linked to, the H+ atom is VERY short lived. At it's creation in an electrolysis cell, it will immediately look for some way to be stable and will thus migrate to the negative plate, take on an electron and pair up with another H atom to form the diatomic H2 atom which is even more stable. This is of course a gas, which is bubbled out and which we are attempting to use in our engine under discussion.
The fact that H+ is so short lived due to it's reactivity is why it is called a radical. That H2 gas, in the combustion chamber, with enough conditions to add enough energy, dissociates back to a pair of H+ radicals. Since there is not near enough hydrogen to combust, the H+ is caught there in the nano seconds before ignition. But, it is not just sitting there. It is very reactive, as you linked to. It looks for something to do with it's reactivity. The C8H18 carbon chain is available and thus suffers the ravages. That is where the domino effect starts in. This happens billions of times a second at the flame front, but if it can be started before hand, we can gain that fraction of a second.
The thing I linked to says that H+ does not exist in a fluid, unless it is a melt yer bathtub (Breaking Bad) acid. The H2 isn't going to just spontaneously split....so when added Hydrogen is in your "Flamefront" it is just H2 till it finds some O2 to combine with.
Why are you insisting that H+ can possibly make it to the combustion chamber when presented with facts that say otherwise by outside sources?
You say that there is not enough H2 to combust, well duh. Nobody has ever ever purported that the H2 was the sole fuel source. (Well some have, but lets not go there) But, the gasoline vapors that are present in a 1000:1 ratio to your added H2 do indeed combust. The .1% H2 combines with O2 and combusts too.
I am VERY skeptical that the H2 in the exact moment of its combustion separates into 2 hydrons and goes around knocking apart a bunch of long chain hydrocarbons, which are themselves in the process of being conflagerated.
Where is your link to a non HHO derived paper or something addressing the "Ravaging" "Shredding" effect of H2 on fuel vapor either in the intake plenum or the combustion chamber? I can find a few papers on aerocap additions to pickup trucks written by PhD candidates & such. Certainly something like H2 seeding of an ICE fuel stream for improved performance has been written about.
The Following User Says Thank You to ChazInMT For This Useful Post:
RustyLugNut (07-27-2016)
