Old 09-06-2016, 11:56 AM   #7134 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by apowers View Post
mora , I saw the video that they first put out with the rtd explorer and they do point out that without motor feedback that is what it does.
Ok so I tried to do another test with the motor but rtd says the port does not exist. This has happened before but now it just will not connect. I spent a lot of time trying to update as the computer suggested but no fix.
Does anyone know of a different way to set parameters without the rtd explorer?
Alvin
Hello Alvin,
If RTD Explorer does not see the port, you will need to look in windows device manager and see what com port number it is showing up as. You can then set RTD Explorer to use that port.
If the port does not show up in the Device Manager, you will have find out why your serial port/converter is not working.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
