Paul, sometime ago you said in mail about resolver
PHEW! Oh, I got the leaf wiring figured out again.
It goes like this:
COSINE NEGATIVE: YELLOW
COSINE POSITIVE: BLUE
SINE NEGATIVE: BLACK
SINE POSITIVE: RED
EXCITE:POSITIVE (EX): WHITE
EXCITE NEGATIVE (!EX): GREEN
The other 2 wires are the thermistor leads.
On the R to E board i see also the GND pin on the input. Do you use it at all?
And on the output, how do we use DOS, DIR and LOT pins? Can i just use A, B and I pins besides 5V and GND? I would like to install 5Pin connector.
A
