Old 12-06-2016, 10:09 AM   #2906 (permalink)
thingstodo
ChargE (not yet running) - '92 Mazda MX6 LX
90 day: 33.89 mpg (US)
Ford Prefect - '18 Ford F150 XLT XTR
Volts / Hz code
Paul - I think this was discussed briefly a while ago, but I don't remember the result:
- do you have any code kicking around for simple voltage output based on frequency output (instead of torque?)
I'm looking for a 'limp home' mode. It seems that the encoder is like anything else in a car - it fails sometimes. I know that it is not efficient to run in Volts/Hz, and that the motor will heat a bit more, and that the torque will be reduced ... but it should get me home instead of sitting on the side of the road.
