Originally Posted by MPaulHolmes
Make sure they are crossed. One drives the high side and one the low side. Right now the high side is plugged into the low side and vice versa. That would be very bad. very very very bad.
So, as long as the IGBT on the right and the middle one have the current sensors, it should be OK.
I will get right to it thanks. I ll get back to you when i rotate the motor.
Wish me luck...
A
