Old 01-21-2017, 04:08 PM   #3014 (permalink)
motorulf
motorulf's Avatar
Originally Posted by kalidasbala View Post
Btw, is there a formula to calculate the precharge resistor value? Also can I use an automotive relay (12v).
The precharge resistor value is a function of capacitance, time and voltage.
I dont have a formula though. Or... i found this
Use a relay that can handle the voltage. I dont think a 12v relay will do the job
You are using 25v as HV and running a 208Vac 3PH motor? What kind of batteries are you using?
I was using a:
Then i used 3 in series, making it 75 volts.
I use them only for testing, for my convenience...
The Following 2 Users Say Thank You to motorulf For This Useful Post:
kalidasbala (01-22-2017), MPaulHolmes (01-21-2017)
