Maybe I don't get it, but it seems like the file bestgasmileage.php in the Forum map contains the following ASCII text:
"Parse error: syntax error, unexpected T_STRING in /home/ecomodder/public_html/forum/bestgasmileage.php on line 106"
If so, and it just displays its content, the original .PHP file must be regenerated.
(EDIT never mind, I just don't get it
Check for strings or extreme values in supposedly numerical data in the fuel log DB.
Run the page with a subset of the fuel log data. If some subset works it IS a data problem.
