Originally Posted by thingstodo
I have 1K resistors in series with the chip inputs. I don't recommend *EVER* removing the series resistors from chip inputs. Even for testing. My clumsiness translates to shorted pins ... and letting out the magic smoke! My scope probes are a bit big to clip onto the chip pins, so I measured on the resistor. 4.4V was enough.
It's a journey ... keep eliminating barriers and you'll get there!
Ok i will use 1k as planned.
I found out i changed encoder aperture logic for experimenting with Leaf encoder. It seems my new ACIM magnetic encoder is different than Leaf encoder and so inverter does not record second pulse
. I have to change AB signal read in code.
A
