Old 04-10-2017, 06:47 PM   #1 (permalink)
ricjas77
FS: 1991 CRX HF - Stock with spare parts
I have stock 1991 Honda CRX HF (high fuel) 5 speed for sale. It has a clean title, matching VIN's, and has never been raced, abused, stolen, or modified. It currently has 280k miles, of which 50k were put on by me in mostly highway miles. It is worth noting that the previous owner had the original engine replaced at 212k due to an overheating problem. The replacement was done at a Honda dealership with a used engine that had approximately 120k from another CRX HF. That puts the engine at about 190k. I calculate my mpg at every other fill-up, and I consistently achieve 50-55 mpg highway and 40 mpg highway/city with conservative driving. I have all the service records and it just had a multi-point inspection from Honda.
Condition summary:
Maintained at local dealership
280k on body/190k D15B6 from another HF installed by Honda
Body has expected imperfections but nothing major
The windshield has a crack on lower driver's side
No rot anywhere on the body but there are several small spots of surface rust (quater panels are good)
A couple small dents
Drivers seat has rips and signs of wear
Rear trailing arm bushings are worn (comes with new set)
Mechanically sound with smooth shifting and no grinds or pop-outs
Underbody is clean
Fuel pump cut-off security system
Kenwood deck with ipod cable
*I have all the service records and below is a summary of maintenance since i've owned it:
Oil changes with Mobil 1 every 3-4k
Transmission fluid/brake fluid/coolant changed
-233k
Timing belt, water pump, drive belts, cam/crank seals, valve cover gasket, valve adjustment, coolant service.
Engine mount
Distributor cap and rotor
PVC valve
Fuel filter
-235k
Thermostat
Alternator
Brake master cylinder
Roof and hatch weatherstripping
-280k
Starter
Rear brake drum shoes and wheel cylinders
E-brake adjustment
O2 sensor
Fuel filter
Professional fuel injector service (Strip & check spray pattern, OHM Test, Leak Test, Flow Test, "Ultrasonically" clean, reseal injectors with all new O.E.M quality seals and filter screens)
Throttle body/IACV cleaning/decarb
Base idle reset to factory
Multi-point inspection from Honda
*Spare parts included with car:
Original hubcaps
OEM distributor
OEM fuel rail
OEM set of Keihin fuel injectors
OEM brand new rear trailing arm bushings
OEM brand new rear quarter glass moldings
Driver's side headlight and taillight
Center taillight
Haynes repair manual
Asking $3,300 OBO
Any questions just ask. Feel free to text for a prompt response: 360-819-5169
