Originally Posted by Ecky
I risk playing the devil's advocate here because I'm a huge fan of keeping classic cars on the road, despite their higher pollution - I honestly don't care if it's a tiny minority of cars - but the standards for a '66 are probably very low, considering it wasn't until the mid 70's that catalytic converters became (almost) necessary to pass emissions.
The problem with some older cars is that they can't stand to a leaner burn without the risk of melting their pistons due to the absence of oil spraying nozzles, having to rely on a richer air/fuel ratio for cooling. But anyway, an eventual retrofit into an old iron to improve its emissions and fuel-efficiency is still most likely to be less energy-intensive than building a newer econobox which would be supposed to take its entire expected life cycle to overcome this initial disadvantage.
