Originally Posted by cRiPpLe_rOoStEr
Was it available only with the 2.0L engine in Australia? Here in Brazil there were 3 engine options, the early 8-valve 2.0L, then a 16-valve 1.6L and a 16-valve 2.0L, and 1.9L turbodiesel versions for export to Argentina and Uruguay. IIRC only the 2.0L 8-valve and the turbodiesel had never been available with automatic transmission.
I don't know about the 8-valve engines but the 1.6 and 2.0 16V were both available here and I actually had both. The 1.6 was a K4VM and the 2.0 was the F4R that was mated with the Auto. Having had both I actually prefer the 1.6 K4M but they are cheap crappy engines and the mechanics hate them.
How did you get that fuel economy improvement in the L300? Adjusting the carburettor to run leaner or keeping lower RPM in a taller gear?
https://plus.google.com/+DavidLyon/posts/MW1qzbFfsDU
I had an electric water pump and a switch. I'd pump water into the carby with a spray module. It was calibrated to work best at 1100 rpm which was low speed driving.
https://plus.google.com/+DavidLyon/posts/jFrdmiMZexL
Due to the increased torque I could drive in the next higher gear.
I found that I could run 50% water by volume and that would give 30% fuel saving going from 14L/100km down to 9L/100km. It also got a lot more power so the life of the vehicle was extended by an extra 10 years over what it was designed for.
A closeup on the next car:
https://plus.google.com/+DavidLyon/posts/3DKGmaFEPvN
It was great to own and drive. I didn't have a good enough system for it to be saleable but it suited what I needed it for.
2003 Renault Scenic - 30% more power with no loss in fuel economy.
1991 Toyota GT4 - more economical before ST215W engine-swap.
previous: Water-Injected Mitsubishi ~33% improved.
future - probably a Prius
