Another possibility is that it only leaks when the fuel pump is on. So you might not notice anything in the garage. Have you tried letting it idle and watching for leaks then? Does it smell like gas after you get out right after shutting it off?
I have also read (about my van's engine, it might be applicable to yours) that it is possible for gas to leak into the intake and use the extra gas there, but this usually comes with a poor running issue.
I think if it is running fine, then it must be leaking before the engine somewhere.
Just some suggestions,
Matt
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
