These are my current settings. It seems the motor-type is correct, however I'm not so sure about the encoder-ticks value. If this is set wrong, what value would I need for the encoder board, 512?
Also, I think I'm getting 4 Index pulses per rotation. I've attached a screenshot taken of just under a full rotation and I can see 3 pulses. Is there any config setting I should change on the controller or encoder board to take this into account?
Edit: I'm an idiot, I wasn't actually streaming poscnt correctly. It seems to be increasing and decreasing from 0-511 along with cw/ccw rotation, but it goes from 0-511 in a quarter turn, with a corresponding index pulse. I may have to alter the resolutiom of the AD2S1210 on the encoder board
