Old 05-07-2018, 05:24 PM   #3230 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
2018 May 7
Upgrade firmware to 21 ... it still says AC Controller version 1.0
Changed motor to type 1
run-pi-test2 displays several numbers - what do I change or what am I looking for ... I guess it's been long enough that I forgot most of this!
Then I did
stream-poscnt 1
data-stream-period 100
And i saw a lot of numbers, but most of them stayed the same when I turned the wheels. Maybe I disturbed the encoder signals? I'll have to make them a bit more permanent.
If I use the same numbers I had from the old firmware, will it still move? Did you change a bunch of the calculations or is that pretty much the same?
I was hoping the new firmware would give me some progress. And I'm sure that it will .. after you explain stuff to me again sorry.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
