Old 08-09-2018, 10:54 AM   #20 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If I had infinite time and a place to level 2 charge I could make it to Amarillo with my leaf, which is around 110 miles with out running the battery into the red.
But I'm trying to save as much gas as possible and at the same have my leaf last as long as possible with lowest operating costs possible.
That means not over inflating the tires to crazy levels, not charging to 100% every charge, not running the battery below 3 bars, not driving or charging when the battery temperature is above 7 bars.
So I drive a gasoline car when I go to Amarillo.
How often is battery temp high? I feel like its been 110 every day.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
