WAI only really help to warm the car up faster and get you out of enrichment or high idle mode. Past that unless you eoc a lot and need to keep the engine hot because it isn't running long enough to stay warm they really don't give you magic fuel economy numbers on steady-state cruising.
For example my Prius functions as a Prius above 170 degrees coolant temp, but below that the engine won't hardly shut off and it uses a lot higher gpm for accel and idle.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
