Thread: WAI or RAI
Old 08-21-2018, 12:06 PM   #5 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by hat_man View Post
Is eoc engine on coast or engine off coast. I only engine on coast. Sometimes in neutral and sometimes in gear.
Engine off coast. You should try it. Get an injector kill or flick the ignition and coast for whatever duration you like then when you want to restart just quarter clutch to jump the engine, then clutch back in to put the motor back into neutral and rev and shift to whatever gear you want. This way tends to abuse the clutch or starter less as you're rev matching more and using less clutch or starter.
I swear 75% of the Prius fe is just eoc coasting and eo at stop lights. The regen system helps a little too but mostly because its built so heavy you can run all your accessories with the engine off for a long time to be comfortable vs sweating my ass off in my civic.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
