Old 09-20-2018, 10:30 AM   #1 (permalink)
slotech
Shady petro-addict
slotech's Avatar
B4 - '97 VW Passat TDI
Arrow FS: 97 VW Passat (B4) TDI 5-spd $650 - Central MN
50+mpg if you are relaxed 245k , clean title, includes many parts
Cash in person only. Shuttle from MSP $19, I can give you a lift from there.
Upgrades and maintenance
- Bosio 1019DLC injector nozzles, calibrated set with documentation
idparts.com/bosio-dlc-1019-injector-nozzles-set-of-p-6091.html
- ECU socketed
- Malone ECO tune chipped
malonetuning.com/ecu-tuning/audi-volkswagen/tdi/ve-tdi
- Frost heater - circulating EBH
frostheater.com
- Aluminum skidplate
evolutionimport.com/odin-skid-plate-kit-for-b4-passat-p/a3004a.htm
- Newer timing belt and idler pulleys, ~10k on it
- Biodiesel tolerant main seal installed in injector pump head
- Transmission oil replaced with oe VW full synthetic gear oil
- SMIC delete, included with all plumbing
- New parking brake lever and cables
- B3 Passat door interiors, manual cranks
TO DO
- New tires
- replace steering wheel clockspring (part included)
- recharge A/C
- new audio system and speakers, thanks previous owner :/
- 5th gear swap for taller ratio
