Old 09-23-2018, 10:05 PM   #2981 (permalink)
Xist
90 day: 29.44 mpg (US)
There is a campaign claiming that Arizona is so sunny we should produce more solar power than any other state. I think AZ is ranked third nationwide. I spent hours and hours researching this law they are trying to pass and finally decided to fulfill some of my adult responsibilities, although I probably watched cat videos instead.
Arizona may have more sun than any other state, I tried to find out for sure, but it does not seem that anyone has tried to compare entire states.
In alphabetic order (hopefully):
Please note that the colors used for each state do not correlate with other states. Sunny states and dim states use the same colors, so you need to look closer.
Arizona ranges from 6.3 – 8.3 kWh/m²/Day and honestly every range seems approximately evenly distributed. Call it 7.3?
California goes from 4 – 8.5 and Imperial Valley is sunnier than anywhere else in the United States. It looks like the vast majority of California ranges from 5.8 – 8.5. Ignore Eureka and say the state averages 7.15? The state is far larger than Arizona with far too many people. I do not see any reason for California to not try to meet their power needs with solar and they have four or five times as many people as Arizona.
I argue that California should produce the most solar energy.
It does.
Florida varies from 4.7 – 6.0, but mostly looks 4.7 – 5.5. 5.1?
Nevada: 5.0 – 8.5. Maybe 6.8?
New England: 3.3 – 4.5. 3.9?
New Jersey: 4.0 – 4.5. 4.3?
North Carolina surprisingly produces more solar energy than Arizona: 4.2 – 4.9. 4.6?
Texas: 4.5 – 8.0: 6.3?
Utah: 3.0 – 7.5: 6.15?
Yes, the Southwest has abundant sunlight, but do you know what else we have in plentiful supply?
Dust and heat.
Neither of those are good for solar power.
“Photovoltaic modules are tested at a temperature of 25 degrees C (STC) – about 77 degrees F., and depending on their installed location, heat can reduce output efficiency by 10-25%.” https://www.civicsolar.com/support/i...l-efficiencies
Mark Rober asked some kids and they installed sprinklers on their solar cells in California, which he put on a timer, and runs once a week: https://www.youtube.com/watch?time_c...&v=a1D-fZP8qJk
Then there is this:
ID:	24873   Click image for larger version
ID:	24874   Click image for larger version
ID:	24875   Click image for larger version
ID:	24876   Click image for larger version
ID:	24878   Click image for larger version
ID:	24879   Click image for larger version
ID:	24880   Click image for larger version
aerohead (09-26-2018)
