Old 10-11-2018, 05:56 PM   #3294 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by BogdanT View Post
More specifically the peak values are pulse values (measured in couple of ms).
The bus-voltage pulses get reflected to a lower or higher extent when they reach the change of impedance at the motor terminals .. I think that's an acceptable translation of the sort-of understandable videos that explain that stuff ...
I have seen 2.25x bus voltage at the output terminals of the IGBTs, before the turn on/turn off resistor values have been adjusted to minimize overshoot. And 2 ms is more than enough time to blow up your IGBTs
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
