Originally Posted by redpoint5
Well, your Avalon has an OBDII port. It's a simple matter to connect a gauge and see what the timing advance is doing.
My Acura runs 40 degrees advance when running on about 90 or above octane, but on 87 does a bit less advance during freeway cruise. When I'm regularly driving the car, I can tell what octane is in it just by feel. It has more power when I load the engine heavy at low RPM.
I got the same MPG though regardless of octane.
I just got my Toyota Techstream today! It's a little glitchy though, but it's also telling me that I need Java 6 update 7 or newer, so I need to find that for the XP computer I'm running it on. I also need a way to charge the laptop via the 12V cigarette lighter plug. But I'll see what it's running at. It will be interesting to know.
Originally Posted by teoman
Call me repetitive but a little bit of water injection could mimick higher octane fuel.
I would guesstimate a bit of water on your air filter.
Ya, I've thought about water injection. But sub-freezing temperatures for a good part of the year kind of stop me from doing that. (It's 29°F right now, and I just drove home from work.)
Of course cool air also increases octane. In my air cooled bug the cold air made it run lean at high load (right around 14:1, via oxygen sensor and gauge). But I couldn't get it to ping, even going up from 5,000 to 10,000ft with my foot glued to the floor and the timing advance about 5 degrees more than normal and the compression ratio increased from 7.5 to 9.5. But I also was using ethanol free, which was also 91 octane.
