Old 12-26-2018, 12:07 PM   #11 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Piwoslaw View Post
My new e-HDI engine has an AGM battery for the Start&Stop feature. I'm looking for info on how to charge it to keep it healthy.
I have been using a CTEK Multi XS 3600 charger on the previous lead-acid. As those batteries like to be charged "low & slow", I used the "Motorcycle" charging mode on the charger - 0.8A @ 14.4V, instead of the "Car" mode of 3.8A @ 14.4V. Apparently AGM batteries need a higher voltage, and this charger has such an option. It's called "Cold" mode - 3.8A @ 14.7V. The instructions state that this charger is for any kind of lead-acid battery, including AGM, but does not mention whether any specific mode is better for AGM.
What do you think? Is 3.8A @ 14.7V better for my new AGM battery than 0.8A @ 14.4V?
Higher charge voltage will help reduce oxidation but you will definitely need a charger that can step down to a float charge. AGM batteries can handle higher voltages but with any lead acid battery you need to use a charger that can adjust the charge rate.
