Old 01-19-2019, 06:58 PM   #11 (permalink)
oil pan 4
The diesel engine wants some boost to be most efficient.
That way you have plenty of air to burn a little bit of fuel.
When I added the turbo on by diesel suburban I picked up at least 10% more fuel efficiency with out changing anything else.
If a gasoline engine is running boost then the engine is producing more power than it would at wide open throttle with no turbo.
