Originally Posted by JQmile
Based on my math I'd have about 12 minutes at 100-150amps but I could be off. I may run it electric only just to see what happens but for now the plan is just to use it as E-nitrous
You can't discharge the batteries past ~50% unless you want them to die VERY quick deaths. And they will sag severely under that kind of load, so I wouldn't expect more than 2/3 the nameplate voltage out of them.
