Old 02-05-2019, 11:48 AM   #3364 (permalink)
jackbauer
jackbauer's Avatar
Found the problem. Seems the call to the space vector modulation routine was commented out so no wonder I couldn't generate any pwm
Still not had any luck with the rotor tuning routine but guessed a few times for the rotor time constand and managed to rip my arm out of its socket trying to hold the output shaft
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
