Old 03-13-2019, 10:33 PM   #3407 (permalink)
59Morris
Originally Posted by 59Morris View Post
Hope to start testing on an HPEVS motor tomorrow.
https://photos.app.goo.gl/Ub14H7pDYxSPZ9r16
It looks like I'm in the same position as the previous two posters. I believe everything is hooked up correctly. Using the "stream" command I have verified the throttle, temperature sensor and encoder are working as expected. When I "run-pi-test2" it does not drop to zero but stays very close to 512. Nothing I have tried so for has made the motor turn. No error messages on startup except the one that says its not really an error. Does anyone have any suggestions as to what I might have missed??
(I'm testing with a 50 volt battery pack)
