Old 04-28-2019, 04:55 AM   #3444 (permalink)
metallica
Originally Posted by arber333 View Post
Your calculation is correct. I can provide real life fact also. My 28kW motor is able to get my 1200Kg Mazda MX3 to 180km/h speed.
That can be because the motor rating is actually continuous 1h rating. Motor can drain 80kW if i push it hard. I am not sure how much of that goes to the wheels, but it is enough my car is quite nimble.
Highway hill climb requires some 35kW to 45kW power at 110km/h.... depends on the grade.
Hello arber333,
Thank you for your contribution, it interests me a lot to know these results based on a concrete case. I note these results, they are useful for me to evaluate the pertinence of my table of values. I will also try to improve this table to better take into account other parameters. It seems to me that my current calculations are a little too approximate
Did you realize the transformation of your car yourself?
