09-19-2019, 11:09 PM
#11 (permalink)
Originally Posted by Adrien
I'm surprised that you say the stock probe is enough, as they can only read between lambda 0.90 to 1.10 (13 to 16 AFR) , however if the injectors don't flow enough, the ethanol mixture could be leaner than this, over lambda 1.40, which is beyond what a narrowband probe can interpret, am I right ?
IIRC the same probe was retained in the flexfuel versions of those engines.
