Old 11-06-2019, 10:24 PM   #1 (permalink)
TexasCotton
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
For Sale/ LiFEpo4 cells/Ultra Caps/Toyota Parts
FOR SALE
LifePo4 cells available
flat silver pouch style cells 3.2V 20ah prismatic pre punch tab holes (used)
yellow brick style Winston cells 3.2V 90ah
blue brick style cells 3.2V 20ah
18650 various cells and mahs
Itronics Ultra Capacitor bank
Toyota parts from 04 Prius Gen2 Hybrid
new SMP PVC valve
new Gates radiator cap
new Beck Arnley thermostat housing
new coolant sensor 2-pin connect
new coil on plug boot replace/repair kit/w spring /rubber/DG standard 16026
……..Toyota style
Radiator for 2004-09 Toyota Prius Gen2 Hybrid
Denso flasher relay 12.8V
Thermostat
5-Lug 15inch Spare Tire/ Donut Toyota style
Scissor Jack/ Lug kit for Toyota
Avco 20931 replacement nylon black push-type retainers 9mm hole
Avco 20578 ……………………………………...moulding retainers 22mm hole
Avco 21237 ...…………..front fender retainer 16mm hole
all of these can be used on Gen2 Prius/Matrix/Vibe/Yaris
Volgen Power supply 120V/230V Input ….58V Output
Harbor Freight
Brake bleed kit
digital Watt -Meter
electric foam cutter
12V circuit tester 42 inch lead
1/4 inch NPT water/oil separator for air compressor
12V LED roll (Elenker brand)E000023 cutting/splice/weather proof
12V LED 2-1/4 diameter round 2-wire blue
12V LED 6 inch x 3/4 inch solid bar adhesive back/ blue
Battery terminal posts 12V
Itronic Ultra Cap bank
Car/vehicle flip visor yellow(night)smoke gray(daytime) driving
pair Halo/angel eye style LED 12V for daytime running (vehicle)
M12/1.5 aluminum lug nuts acorn style fits Toyota thread style
Plus more to come
Once email ,physical address, agreed price, terms, etc. . ..Therein will ship to 48 states USA domestic and request pay via PAYPAL
thank you and questions are welcome
