Old 11-11-2019, 10:25 PM   #303 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
I'd love to have weather in the 40's. It's supposed to get down to EIGHT here tomorrow.
I want to say the highest load I've seen lean burn hold was around 91%. Would you have any interest in my old ECU? I'm not sure if the plugs are the same, but I have no use for it at least.
Crazy cold! Coldest it's been down here so far was 33 *F at 6-7 in the morning a couple days ago. I'd like to be able to keep above 80 mpg this winter, but we'll see. Considering that Michigan already has snow this may be a hard goal to meet, since I was getting in the 70s last December back home in a milder winter.
I've seen lean burn as high as 92% load before, but not very often. Usually when I go above 87% load it kicks out. Maybe when I'm that close to the threshold my foot just isn't steady enough to keep it from deviating a percent or two. IIRC someone on IC posted at what TPS the car will go into lean burn and when it kicks out, so I'm hoping that'll help some.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
