Well I have an update. I got a 30 plate 3/4 inch heat exchanger that I recently installed. I got a sandwich plate and made my own 10AN oil lines to run oil through the heat exchanger and rerouted the heater hoses so the coolant runs through the heat exchanger before the heater core. Looks like a huge improvement in temps so far, but I only ran it for about 2 minutes total, so not sure yet.
The problem is that my sandwich plate has a defective flare fitting that is causing my line to not seal correctly and drip oil, so I had to take the sandwich plate off for now until I can get a replacement fitting for it. So far the results look very promising, I will report back when I get a replacement fitting and I am able to run it for a while though.
