Originally Posted by aerohead
If the extension is elongated along the streamlined 'template' contour,and a side curtain is extended downwards to close the underside gap,such that creates the 'K' truncation,no separated flow will exists 'above' the aft-body,and all low-pressure,base pressure will be acting longitudinally,behind the vehicle as a drogue effect,with zero lift.Streamline bodies are incapable of generating lift.
Did you look at the video I did on the Porsche Cayenne, linked in the above post? They quote real data from a real car which supports what I said. (And of course, there are plenty of other examples of this on other cars.)
And streamline bodies cannot create lift? Unless you are using a unique definition of what streamlining comprises, streamline bodies can certainly create lift!
