Originally Posted by aerohead
... If you had a horizontal rubber fin,on the edge of the hatch,just above the blue oval badge, this might help keep some of that dust sequestered away,but it would need to be rubber,for pedestrian safety. ...
I can visualize it, but do you know examples? I think eagle could experiment with sturdy cardboard fins, attached with painter's tape, which should hold fine for testing in a spot like this on the car.
Originally Posted by eagle
that is what I am talking about
I am thinking that apart from the extension the sides should come down and be "bent" / enclosed to the inside for a more boat tail effect
You can experiement with lots of positions. Tuft testing will help you understand what to keep.
