Originally Posted by California98Civic
Do you mean a Gen1 Insight without the hybrid elements? Is that actually possible? It would be a 20% drop in HP over a stock CRX HF, yes?
Stock 2nd gen CRX HF had 62 HP @ 4500 RPM. Insight (without IMA) had 67 HP @ 5700 RPM. This CRX, like most, has been swapped.
I'm sure the swap is possible, but it wouldn't be a drop-in. I've often wondered if the IMA motor can be removed if a Fit flywheel/clutch is used. If left in place, the IMA motor can be used as an alternator.
