Thread
Snagged a free snowblower: Ran when parked. Not eco.
04-11-2021, 10:24 AM
13
permalink
Piotrsko
Most carbs on small engines are made of MAZAK a zinc based alloy that is sensitive to water corrosion. Might also have the bleed fuel hole clogged up or the main jet hole ditto depending if the plug is wet or dry.
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
MetroMPG
(04-12-2021),
Xist
(04-12-2021)
Piotrsko
View Public Profile
Send a private message to Piotrsko
Find More Posts by Piotrsko
