Originally Posted by pgfpro
I did some calculations on how much the usage nitrous would cost for 7lbs. It came out to around $30.00 for 12 gallons of gasoline or 603 miles. On waste solvent it would be worth it to test the numbers.
So, you already have a comparison baseline for the usage of gasoline and NOS, yet you still didn't try NOS and waste solvent? Do you have any clue about the solubility of some solvent on water, which could eventually enable its usage as the antifreezing fluid instead of methanol which is widely mixed with water on the supplemental injection setups?
