Originally Posted by pgfpro
I do know that the waste solvent much to my surprise can't make anymore then 250HP due to knock issues. I thought for sure the waste solvent would be a great fuel for HP but much to my surprise it sucks. I've ran it way richer at high load and lean and it made no difference it still is HP limited because of knock.
I must confess I was quite curious when I found out you were actually using waste solvent as a motor fuel, exactly because it's not the most appropriate one. I still remember watching the news and reading about how badly damaged some engines would get due to adulteration of gasoline with solvents which was a common problem in my country in the late-'90s.
