Old 05-03-2023, 04:16 AM   #38 (permalink)
cRiPpLe_rOoStEr
Afaik, on a flex fuel usa car, the conditions map was increased to accept out of parameter temperature conditions caused by the alcohol. IE: different exhaust temps with no corresponding other symptoms would now be acceptable then add more or less fuel.
It's the same elsewhere. What I meant is, as most cars with EFI have oxygen sensors anyway, some folks actually tried to run on ethanol on non-flexfuel models expecting the EFI and ignition to compensate. Sure a CEL might be triggered once the ECM is not programmed specificly to handle a higher amount of ethanol.
