IIRC there has been discussion here of wheel rims which would "pump" air outwards, reducing pressure under the car.
The reduced pressure would have to fight the suspension springs, and the outcome of the discussion seemed to be that the increased pumping losses outweighed any benefit from potentially reduced underside aero drag and/or temporary lowering of the car (assuming the suspension gave in).
Given this outcome, these rotor/fans might lean towards the
unaerodymic thread.
Anyway, these do not work well with smooth moonies, so, yeah.
What matters is
where you're going, not
how fast.
