1/11/2025 UPDATE:
Got the FE modified intake mock upped. This Intake has the N20 system I use for FE to increase flame speed during extreme Lean-Burn 30:1. I'm going to use this during the drive part of Drag and Drive events. Then switch out the intake, injectors and T/B as a whole to the race manifold injectors and large T/B. Also, when I'm daily driving it or street driving during a Drag and Drive event I'll be using the rear 16-gallon pump gas fuel cell.
Also added front vertical bars to the front fenders. After calculating the down force, it had me worried so went ahead and added these bars. Once again, their mocked up and will have grade eight bolts and an added .1875 steel backing plate.
Pressure Gradient Force
The Positive Side of the Number Line
