Old 05-07-2025, 11:47 PM   #18 (permalink)
Macskyver
Macskyver's Avatar
I've been getting to work gutting the interior of the LS430. Initially, I was on the fence between keeping things mostly stock interior-wise and going all in. I am glad I decided on going all in. There are just so many plastic pieces and lots of them are incredibly brittle. They crumble to pieces if you look at them wrong. The interior also looked pretty good from far, but it was definitely far from good.
Here is the dash getting removed. You can see how it has the common issue with these vehicles where the dash bubbles.
After dash and seat removal and some cleanup:
Here's the back after removing the seat and carpet:
I also got the headliner and sunroof mechanism removed:
The sunroof is quite heavy. I think deleting it is the right choice. I'll be making a cedar strip panel to fill the hole. It will be similar to an aeroshell I made for my Tundra a while back (build thread for that is here on Ecomodder). It will be super lightweight and should look good.
